Im leaving to London for 6 months and my 04 Cayenne Turbo will be parked.. What is recommended for keeping this car parked this long?  Should I disconnect both batteries or just the one under the seat?  Drain gas? Jack stands??  Any ideas?
Do not jack the car up on stands, let it sit on the ground.  Clean the car inside and out, apply a good coat of wax.  Air up the tires, change the oil and filter, add Stabil to the fuel tank, fill the tank, run for about 15 min. before parking.  Use a quality battery maintainer.  When you come back in six months, it will fire right up and be ready to go.
I do everything noted by JFP with a few extra steps (park on thick mil plastic sheeting, use desiccant in the cabin and trunk/frunk, and cancel parts of the insurance to save $$$). My Porschse routinely have sat in winter hibernation like this for 5-6 months, and been doing so for over 8 different winter seasons. All-is-good.
i always over inflate my tires on my track car so i don't flat spot a tire.
For fuel i completely drain the system, but you most likely don't have the capability.  Perhaps look for fuel that does not contain Ethanol
Battery maintainer or disconnect completely if you aren't need power.
