I searched under DIY tools, but nothing came up for these codes.  I think I'm not searching correctly as I'm sure they're all here somewhere.  Any instruction on that is appreciated.
In the meantime, my 06 997 C2S is giving me a warning 'check front left side light'.  When I read the codes I got the following reading below.  When I cleared the codes and short tested all modules, the 8042 front luggage compartment unlocking remained.  I didn't drive the car so it's possible/likely that the other ones will come back.  I suspect the fog codes are due to the ROTtec drls, and have requested them to send me the resistors that may fix the problem.  But what does the luggage compartment one mean?  The locking mechanism works fine (as does everything else)?  I'm surprised that it would not clear.
Any advice is much appreciated as always.
post-72955-0-34762400-1404705297_thumb.p
Thanks, Loren.  How is programming the front control module done?  With Durametric, or is PIWIS needed, or is it something simpler than that?
Just to be sure check the fuses too..
Sorry, you will need a PIWIS or PIWIS 2 to re-code the control module.
Unfortunately this happens occasionally on 997-1 series cars.
