Do both fans come on at the same time? Today I was out with the A/C on and noticed the driver side fan was running. Passenger side was not. Engine temp was something over 185. 98 Box if it makes any difference.
Yes, both stage 1 (slow) and stage 2 fans (hi speed) run at the same time on both sides.
Check your fuses and then you might have a bad ballast resistor on the passenger side.
