I had an occasion to bring the car up to just past 90 a few days ago.  At about 92, the front seemed to be really light.  Is this 'normal'?
90 mph is a decent clip,
assuming your vehicle is road safe and does not have loose suspension bits,
tires, pressures, alignment and shocks come to mind.
I would say no, not normal. These cars were made to be driven on the autobahn at speeds almost twice that... I routinely get mine up to 120ish and it is solidly planted.
Mine felt light at those speeds and higher, replacing standard front bumper cover with a GT3 cover added downforce, and it felt more stable. If all your suspension parts check out Ok, then you may want to look into the aerodynamics.
I've checked the suspension on a lift before getting a recent alignment and everything seemed tight.
I did fnd another road and got it up to 101.  This time I was more conscious of the steering and it felt stable.  I think the other road I first tried - which I normally drive 55 on - there are slight pavement wallows that - when going 90 are amplified and make it feel unstable.
I really need to do a PCA DE track day to get a better feel for this car and it's capabilities though.
Edited by steve20186
I had the opportunity to drive a new 997 (I know, it's not exactly the same) on the autobahn in Germany a couple of years ago.  The fastest that I went on the unlimited speed sections of the autobahn was just over 240 kilometers per hour, which is roughly 150 mph.  I noticed that the front end of the C2S that I was driving got a little "floaty" around 150 km/hour and it stabilized around 175 km/hour.  I found this to be the case on multiple occasions.  I think it's possible that what you're experiencing is normal.
Like suggested above and a few more:
Alignment
Good tires
Tire pressures
Maintained suspension
Matching tires
If directional tires, are they correct
Rear spoiler- proper function
After I had my 996 (Carrera 4, 2004, 86k miles) raised in jack stands for multiple months, I assume my suspension took a hit. All tires are in a really good condition, pressures are good. Just changed my engine mounts.
When I drive around 50mph to a curve, accelerating hard but still without losing traction, the car rolls considerably and my front feels really really light. Doing quick steering movements on a 40+ mph speeds is scary. The difference is drastic when compared to the time just before I put my car on jack stands. Could it be that my spring coils took a hit?
I'd be happy to start another thread, just let me know. Otherwise, please throw any ideas how to check or measure my suspension. I'd also like to inspect it myself before I drive my car to Porsche shop. I know engines reasonably good but I am a newbie to suspension.
Thank you!
Edited by Domiac
No need to start a new thread on my account.
I assume that your stands were under the chassis letting the suspension hang?
Yes. Multiple times I had a thought that I probably should raise suspension a bit too to relieve stress but I never got into it :-(
To my understanding I have jacked the car always from proper places. I have removed my engine & transmission twice and the car has been on jack stands for around 3 months or so in total.
Noticed today that my front left fender is almost 10mm / 1cm higher than front right. Back fenders are at identical height. Took measurement multiple times on different locations, car was level. Definitely something is off on front suspension.
