During my last track event, I thought my car was lacking a bit of power. Maybe, maybe not. But when I checked with my Durametric cable, I got this error.
Bosch Digital Motor Electronics Motronic 7.8.1 Turbo
Current Fault Codes
P2004: Catalyst system efficiency below threshold bank 1
Value below lower limit value
It appears it could be something with the pre or post cat O2 sensor.
Any one seen this issue and fixed it? And which side is bank 1?
Current Fault Codes
I would be concerned about the cat it self considering your comment about the track.  At this juncture, I would be looking at the performance of the pre and post cat O2 sensors, looking for how they cycle (or fail to).  You could have a cat going out, or a bad O2 sensor, you need to diagnose which one is the correct issue before spending a lot of money.  The following charts are for a Boxster, but the operational theory is the same for your Turbo:
ThreewaycatandO2sensoragingdiagnostics_z  ThreewaycatandO2sensoragingdiagnostics2_
JFP is giving good advice as usual.  Use your Durametric to log the precat and postcat sensors and you can chart the data (or see it live in Durametric) to compare it against the charts he provided.  I had the same issue on a Carrera 4S and the cat was bad.
