Hi all!
I purchased a used 2007 987 Boxster recently which came with an AUX cable from the CDR-24 unit. I never bothered to ask the previous owner about how the AUX cable worked since I assumed I just need to plug in my iPod and listen to the music. Turns out it's not as easy as that. I don't know if a FM modulator is installed or a Dension (I assume these are the only two options available). Any suggestions how to determine which one is used and how to get the AUX cable working ? Thank a ton for all suggestions and help!
Forgot to mention, I have the basic sound sytem (Not sound plus or Bose installed)
Hi all!
A bit late on the reply, but on my car, you select Aux.   Press the "s" button" until Aux shows up on the display.
