Does anyone know if it's possible to reset an "Air Bag Fault" without the PIWIS?  I had remove the front seat to pull the carpet back and drain the lake from the dreaded clogged sunroof drain and now i have the fault.  I only get the light, i don't get the common P1217 code that's attributed to the underseat connector.
