Folks,
I am looking for the best place to get 2 new rear tires. Either online or in Southern CA.
I need the Michelin , Pilot Sport, 285/30/18
Any reference would be much appreciated. Obviously I am looking for the best value.
Thanks in advance!
JS
Folks,
One more question. In looking at Tire Racks website I am not sure which tires I should be looking for.
The Pilot Sport does not look like my original equip tires. The tread type has that "directional" look. Its also not available in the size I need.
I then looked at the Pilot Sport Rib and that looks more like my tire. Is the Rib the factory replacement for an 02 Cab?
Thanks in advance.
js
Folks,
Thanks in advance!
JS
Rib is the OEM for Michelin Pilot Sport. They are in 285/30/18 size.
Check prices are tirerack, add another $22 for mounting, balancing, stem. That should be your guide on prices.
Ask to see if Costco can order these. I've always had luck with them but they do take 1-2 wks to order. Otherwise, I've heard wheel enhancement is a reputable in place. Ask local tire shop to match Tire rack prices too or just order from TR.
You may have better luck but the Costco here in LV cannot order them. Check the local discount tire, I got the local DIscount Tire to match the tire rack price and then add $30 per tire for mount, balance, etc.
