Hi Guys,
I've got a 05 Cayenne S. I've removed the trim panel and gotten most of the rivets out in an attempt to get to the actuators.
But my question is... can I replace the rivets with screws? If so, does anyone know what size and type?
.C
I recommend removing the entire frame. I drilled and replaced the rivets once thinking it would be easier than just removing the entire frame but the second time I found that it was much easier to take it completely apart. And adjusting the window frame is fairly straight forward.
Same here with ricker - it wasn't a big deal to realign the frame into the door skin.  Leave everything dirty and it's easier to see where things were adjusted.
