The foam covering the doors/flaps of the air housing assembly (where the A/C evaporator is) is failing and pieces of foam are coming out of the A/C vents.   I intend to have the doors replaced.  I have spare door frames (uncovered) and I would like to cover them with suitable material in preparation for the replacement (Porsche does not sell the doors separately from the air housing assembly).  Could somebody make a recommendation on the material to use?  I am concerned about both durability and the ability of the doors to seal properly when closed.
Thanks in advance
I had some thin foam (forgot where it came from) and I just used some 3m spray adhesive to apply it to both sides of the door.  Worked fine, no issues after 6 months.
I just did this a few weeks ago. I used the widest window weatherstripping I could find at Lowes. It's a one side adhesive foam. I wrapped it all around the the door, wrapping around the edges. I then covered the whole thing in duct tape. Kind of a redneck fix but it works great. I had zero foam left on the door/flap. A/C is nice and cold now.
Here is the DIY link: http://www.renntech.org/forums/tutorials/article/121-fixed-my-lack-of-heat-problem-here-is-the-procedure/
Edited by Porsche Pilot
I'm having this EXACT same problem.
Where do I find the doors/assembly??
Try a used parts shop
LOL...No, no..LOL.......I mean where in the car is the door/assembly located!  :)
Thanks for the link and the suggestions.
It's not an overly complicated procedure, just a bit fiddly. If you decide to perform the DIY I can talk you through any issues. The whole thing took me about 5 hours with a few beer breaks in between. The hardest part was getting under the dash as I had to contort myself in ways only a skilled Russian gymnast can.
So if you end up making the door/flap essentially "solid" with duct tape...why wasn't the door solid from the factory?  What's the point of the round cut-outs?
  • 4 months later...
I am working on a 1999 911 and I am trying to get to the metal air flap under the cowl. I have it all apart but I wanted to know if there is a special way to remove the heater (Part with the coolant lines) out of the way. I took the two bolts out and it moves but not enough to get out.
