The windshield washer tank leaks on my 2000 Boxster. When filled, fluid runs straight through. The pump motor makes good sounds but never pumps anything so I'm thinking the line from the tank to the pump came loose. I did find a post suggesting that Boxsters once had a problem with a wimpy clamp on this line, so I may be on to it.
How do I get my hands on all this stuff? I'm thinking I need to remove the left inner fender. Is that right? If so, any tricks to doing that?
TIA
"00 Boxster
Edited by jefla
My windshield washer tank leaks. When filled, fluid runs straight through. The pump motor makes good sounds but never pumps anything so I'm thinking the line from the tank to the pump came loose.  I did find a post suggesting that Boxsters once had a problem with a wimpy clamp on this line, so I may be on to it.
TIA
I have the same problem, it started two weeks ago and I haven't had time to resolve it. :help:
