Hello Forums,
My 05 Cayenne S's Front RIght seatbelt is not retracting. I need to manually feed it back.
Also, it clicks when I feed it back in.
Does anyone have any ideas on a fix?
Thanks.
Christopher.
Enzo,
Problem with mine was "pinching" between plastic cover and the seatbelt assembly, likely happened due to warped shape and changes as the vehicle aged. Fiddle and reshape the plastic cover to see if it helps.
I fixed my problem by pulling the half crescent cover outwards.
