2002 996 Carrera 3.6L
I dropped the engine/tranny. I needed to fix an oil fill tube and a rear left side wire harness issue. Car ran before the work. I now have the engine/tranny back in the car. I dont have the transaxles hooked up or the clutch bleed. The rear of the car is still up on stands. I wanted to try and start the car before reassembling everything. Well the car turns over but will not fire. The only idiot light that comes up on the dash is a temp sensor failure or something like that. I went back through the book and I seem to have everything hooked up. I know a motor needs four things to fire air, fuel, spark and compression. The fuel pump can be heard upon turning the key on. I get fuel to the connection on the top left side of the motor. The air box is removed. One thing I havent checked was spark. The spark plugs where change less than a month ago and it ran before. I dont recall removing anything that would remove the spark. Is there a connection at someplace that removes that from the coils that I could have disconnected.(I will check spark tomorrow).
Sorry guys I am really searching here. Not sure what exact info you all would need. The car has been sitting for about 3 weeks no fuel or power. Any suggestions onthungs to look for or try would be very helpful.
Ask for any info you may need and ill do my best to provide it. Thanks.
Edited by SLC911
Can you explain a little more as to the harness issue?
There was a short caused by the license plate light wires. It melted wires through the harness, that I fixed by splicing. Which brings up the question of if the O2 sensors are not connected properly would that prevent the car from firing? :huh:
Edited by SLC911
No, the O2 sensors will not prevent the engine from firing. However, a bad coolant temp sensor reading may change the air/mixture so much that the engine won't fire up. If you do have sparks, I would check the coolant temp sensor and MAF connections.
If you do not have sparks, I would check the connections on the throttle body, crank position sensor, and cam sensors.
Where is this coolant temp sensor located? How many MAF sensors are there, I thought just the one that goes into the air box?
There are 4 bolts and one electrical connection to the throttle body.
The coolant temp sensor is #2 here and yes, you're correct on the MAF and throttle connectors. I think verifying the sparks will be the next logical step like you said before.
741372d1373035791-2001-996-c2-coolant-te
If the pulse sensor for the flywheel is faulty the fuel pump will not continue to run and the engine will not start. This is a pretty common problem. It happened to me once when I had my engine out. The fuel pump will run when you turn the. Key on so this can be deceiving. Check the signal from the sensor.
The idiot light is a thermometer temperature display with the words "failure indicator"
I did a quick shot is starting fluid it acted like it wanted to fire but didn't. Not sure where that leaves me.
Another thing was I turned the crank while putting the serpentine belt on. Would that change timing?
Is there any wires on the left side harness that would control firing of the motor? I thought most was on the right side harness.
OK OK rookie mistake... C2 FUSE sorry everyone for being a DA
Thanks for all the ideas and advice. Now on to bleeding the clutch.
Saved me a lot of typing :-)
Glad it was something simple.
mike
