I'm going to install a GT3 style front sway bar on my 99 C2 and have been looking at the Tarrett extended front drop link set which provides a collar for the upper mount point which either slips (or is screwed on-not sure) over the bottom of the front strut. I have PSS10 coil overs on the front/rear. Do I have to pull the entire shock assembly out of the car to slip these collars over the bottom of the strut or can I simply unbolt the wheel carrier, drop it away and get the collar over the end of the strut with out unbolting the top? Most of the DIYs show the top being unbolted, dropping the wheel carrier down and then pulling the strut out of the bottom.
Talked to Tarrett the coil overs need disassembly with the collar going on from the top side.
