We have determined that hte oil pan gasket is leaking and I am going to unbolt the lower plate of the oil pan and replace the gasket during our oil change this year. Can anyone provide the tightening torques for the bolts to the lower plate on the oil pan and what liquid gasket is called for? TIA!
I wonder then if I could "patch" this then with some sealant of some sort on the outside where it is leaking if I cleaned it up...any thoughts?
