I just purchased a 2006 911 4s a month ago and everything was fine until i was driving to work and a message poped up on my screen and next thing i know i lost my signal lights, emergency flashers and headlights. And for some reason the power to trunk was lost!
I checked all my fuses in the drivers footwell which looked fine. Is there more fuses in the trunk or somewhere else? Could it be a relay? Also i have heard it may be an ignition switch, would that be a good possibility? Any help would be appreciated!
Thanks Del
Thanks Del
Ignition switch electrical gremlin's are legion with these cars, to the point that most shops stock replacements. Fortunately, the switch is cheap and is a DIY project. Check the archives, there have been multiple write ups on the subject, including this one: http://www.renntech.org/forums/tutorials/article/24-996-ignition-switch-replace-just-the-switch-with-pictures/
Thanks for your help, someone i know had owned a 2000 911 and he told me the same thing. The only thing is if it is an ignition switch would that still include the emergency flashers? Also i have taillights but no headlights? And for some reason now i can't pop the trunk so is there another way to manually open it?
So yesturday i was taking it home from work and decided to try the signal lights and sure enough the were working again along with the emergency flashers, headlights and i had power again to my trunk.
Since a couple people mentioned ignition switch i turned it back and forth about 5 times but not sure if that is a coincidence or not?
Anymore thoughts now that it is back working?
