Hi guys. Had a mechanic friend over last night with a professional diagnostics tool (Launch)
And we Did a complete scan. I wanted to see if i had any coil codes as i sense a little strutter/Shake now and then at idle.. The car is new to me ,a week Old, and i LOVE it. So i want to Get it at full form.
We pulled no codes for could but there was a0907 code. And we could not erase it. Would this fault cause any noticable symptoms? I have no displayed messages or lights suggesting fault on my dash and the car operates seemingly fine,a part from the stutter,
I know previous owner changed alternator about 10k ago.. Could the 0907 hang from then? I've understood its electrical related battery/alternator etc..
Any addition info is appreciated.
Not familiar with A0907, I would suggest you scan all modules to see if it shows up anywhere else. Sometimes a transmission or gateway fault will show in the DME and won't clear until you address the module it pertains to.
I see there should have been a space there.. 0907 is the correct code.
I've tried searching around and i've seen some say most cayennes have it.. Not to pay Attention to it.
I have no other codes on the truck now (besides 0907)after I changed plugs/coils and cleared the codes from that ECU.
My only guess is it's hanging from when previous owner had alternator issues . And the diagnostics tool we used,although professional, can't get to that code to erase it.
Fault 0907 -- Load management operation on vehicle electrical system/DME control module
Possible causes of fault
- 'no display' Loads are/were switched off temporarily. The load management operation was enabled because of undervoltage.
Most common cause battery replacement.
Clear it and it should not come back (unless there is some other cause like a pinched or broken wire).
