Hi all have an 07 turbo LHD with Pan roofs
Nothing works but I can manually wind roof open or closed
If I press the roof switch to reset it I hear a click after a few seconds, from .drivers rear wheel arch area.
Does anyone have a wiring diagram and operation guide, also don't know if connected the car has an airbag light on,because it has non standard front seats could the SRS module disable the sunroof
The roof blind does not work either fully open at present.
As you guessed only bought the car recently last owner gone AWOL on me
See this procedure:
If any of the points mentioned below are suspected to have happened, it is recommended to relearn the end positions for the control unit. Before learning, switch off the ignition and switch it on again.
To learn, the knob (emergency button) is to be pressed in the position 'Roof completely closed' until the roof is completed closed. First the sun blind closes completely, then the roof segments A(1) and B(2) and C(3). Learning the end positions must be carried out to completion, otherwise the roof cannot be electrically activated.
Note- The end positions must be learned when:
- The roof does not react when actuating the switch
- The end positions of the roof segments are not correct
- Battery or terminal 30 were interrupted
- Emergency operation using the crank was carried out
- Components (control unit, motor, elements) were replaced
- Roof segments or components were adjusted
Before teaching the end positions, the knob must be in the position 'Roof completely closed' and the ignition must be switched and switched on again.
Tried that in my handbook it say turn knob to closed position and then tilt the knob which pushes it up , you heare a click after 10 sec
But the blind doesn't close or anything
PIWIS won't read the roof are there any relays I can check the wind deflector and front glass panel all move with the Allen key
No they have not, the MY in the VIN# will either 6 (2006) or 8 (2008).
