2009 997.2 DFI PDK
Oil pressure reads 1 bar at idle - occasional warning for oil pressure when high temps reached.....
I noticed it has a new style sender thats on the back of the oil filter housing.... I know the older ones are prone to failure.
Vehicle is low mileage with clean history
Any recommendations?
Cheers,
D.
2009 997.2 DFI PDK
Cheers,
D.
What oil is in it?
5/40 fuchs synthetic i believe.
Possible that the oil has broken down as the 997.2's tend to run hot. Try an oil change and send out a sample of the old stuff to see what condition it is in.
ok thanks,
oil is fresh, didnt think to keep a sample.... next time.
I have a sender on the way to try. either way at least ill have a known good test unit...
cheers.
