Hello folks,
I have a 2001 996 cabriolet with a hydraulic leak on the drivers side piston. I recently had to add hydraulic fluid to the convertible top reservoir, but it immediately leaked out of the bottom of the piston.
Is there any fix for this or do I need to replace the entire part? has anyone else encountered this problem? Where would I purchase parts for this fix?
Thanks in advance!
Klaus at TopHydraulic is very reasonable in rebuilding hydraulic cylinders for Mercedes. I assume it would be similar with Porsches. Give him a call and see how much.
Mdreef,
My 2004 C4S Cab had the same issue that started on the driver side, unfortunately I am not as astute as a mechanic as the majority of the people in this forum and I had it replaced with a new OEM cylinder from a local independent shop.
Then within 6 months, the other one on the passenger side went out......same issue. Hydraulic fluid dripping from the back wheel well.
You are correct....these are not cheap to fix, but living in a Convertible weather, it is a must. If you can get them both repaired at the same time, by all means do that. I would have.....
Good Luck.
Thank you for this advice. I planned to only rebuild the leaking side, but now I will do both, as I suspect the other one is probably on its way out as well. I plan to take them off today and send them in to Cabriolet Hydraulics.
Thanks again!!
Just to add a thumbs up to a vendor, I exchanged my cylinders for rebuilt's through Cabriolet Hydraulics.  $450 for both; came with detailed removal and install instructions, very well packaged including a bottle of hydraulic fluid. Zig (owner) was readily available for any questions.
