Cayenne Secondary Air Injection Pump/Valve DIY - Replace/Repair
Symptom: CEL light comes on and when investigated, P0492 code (or similar) is detected.   The following code description is observed in Durametric SW: Secondary Air Injection System Bank 2 - Value below lower limit value, test conditions are not-completed, fault is currently active and causing a DTC lightWhat is wrong:From my experience and from others' posts, this is usually caused by the failure of the secondary air pump that is located inside engine compartment (the two horn like structu
If anyone could please help me out with diy for replacing SAI check valves on 04 cayenne turbo, it would greatly be appreciated. Cheers Dylan
Are you using TapaTalk? This is a TapaTalk bug that has been reported but not fixed yet.
Leave TapaTalk and use a web browser and everything will work fine.
  • 8 years later...
