I asked about this before and I have just kind of lived with but it does bug me every once in a while. My 40th AE seems to sit a little higher passenger rear on side than the other. There is about a .5 inch maybe difference in the wheel well gaps between the passenger side rear fender and the driver’s side rear fender the driver’s side to top of tire being the lower one of the two. I've measured this while parked with no one sitting in the car. It seems to me that since the installed OEM x74 and has had almost 10k miles to “settle” this would have sorted itself out by now.
Is there was a way to level x74 suspension? Car drives fine and alignment done since and tire wear are fine it’s really more of an I KNOW it is there and kind of bugs me. I know can’t corner balance non-coil overs so any options available to even this up?
Hmm... It sound like something is not right and this might require some dis-assembly and measuring.
Things that come to mind are:
- a coil that is not properly seated
- a mismatched set of compensation plates (one side larger than the other - which might also imply mis-matched springs)
- a missing or wrong size bump stop
Loren, I though same thing about spring seating. However, after 10k miles coils has to be seated I would think,
My indy looked at everything looks ok. I know springs had the proper paint dots on them to be x74 so don't think that is it.
Educate me or point me to more info on compression plates or bump stops.
As far as I know using OEM bump stops. Why would bump stop cause ride height discrepancy on a static cars suspension not under load?
What are the correct bump stop part number for x74 front and rear?
Edited by MiamiC70
You are making the assumption that it was properly assembled in the first place.
If you can not see anything obvious then you will likely have to remove and inspect the pieces - sorry.
