2008 911 TT bonett will not open with Key,Latch Swich and with Emergency Cable
I can here the selnoid on the front drivers side move when operated but hood will not pop up
The steel cable will not do anything as well.
Did you try having someone gently push down - while you pull the emergency cable?
If that works do not shut it again until you re-align the latch or replace it.
