There seems to be a particular spot when I turn the wheel where I get a squeak. It is more noticeable at slow speeds because of the amount that the wheel is turned. It does sound like it is coming from the wheel or column rather than anywhere else. I was going to get the front wheels off the ground and turn the wheel to isolate where the wheel/column squeaks, then remove the wheel to see if there's anywhere obvious to apply lubrication. Does this sound like viable approach?
  • Like 1
