I had a constant alarm on the washer fluid didn't ever see it leaking after filling finally looked and found that the left front headlamp washer hose was disconnected. I filled it up, no leaks but still getting the alarm when turn on the car. Hooked it up to Durametric and there are no faults. Any idea why that is still throwing?
Thank you
I had a constant alarm on the washer fluid didn't ever see it leaking after filling finally looked and found that the left front headlamp washer hose was disconnected. I filled it up, no leaks but still getting the alarm when turn on the car. Hooked it up to Durametric and there are no faults. Any idea why that is still throwing? Thank you
Possible that the fluid level sensor is going south, it is replaceable, but be sure to drain the tank before taking it out.
I would check the wiring and the connectors too -- lots mud and corrosives can get up in there.
Good point..............
