When I lift either the interior or exterior door handle, the window goes down about 1/4" as normal. The problem is that when I release the handle, the windows goes back up (even though the door is not closed) so that the door will not close correctly. I suspect there is a switch that registers whether the door is open or closed and it has gone bad.
Any thoughts on this?
Edited by The Beanster
Had the exact same issue - on drivers side. Mechanic tried to fix but no luck so finally they had to replace.
