Hi, I have a 2003 Cayenne turbo. The rear passenger door will not lock when I use the fob or the keyless button on the external door handles. To get it to lock I have to remove the rubber grommet and manually move the lock override to lock the door. I suspect it is a faulty lock mechanism. The door clicks 2-3 times when grabbing the handle vs once for the rest of the doors and the underdoor light flashes. I looked up the part and noticed there are 3 versions of the lock.
Does my diagnosis sound accurate?
What are the differences in the 3 lock models (I4K3, I4K0, I4F2) and how do I know which one my car has?
Thanks in advance for your help!
I just replaced all 4 to brand new spec. Will look up the parts numbers for you tomorrow. My driver door won't shut and passenger door won't open sometimes. plus the rear acting up.
Let us know what part your replaced, my 04 has been doing the same thing intermittently. I am now in the habit of making my way around to double check the door because sometimes it will lock and other it wont... but it always unlocks.
