New here so hello to everyone.
First small? problems with my MY02 996 C4 Coupe.
If I lock car manually using key, then I cannot open car using key without alarm sounding, no 10 second delay as suggested in manual.
Once alarm is sounding I can switch off by inserting key in ignition and turning to position 1.
2nd problem has occurred twice, but whilst driving, both windows fully open and courtesy lights come on?
Any suggestions?
RH
  • 10 months later...
Did you ever find out what the solution was to your windows? By chance my car did this twice yesterday and twice today. Each time the courtesy light goes on and both windows fully open. A few of the times they went down when I was shifting. The last time the car was in 4th gear at a constant speed.
Didn't find a solution and it is still occurring, particularly when cold. Porsche service center said it might be faulty door locking mechanism.
Interesting. I also have a 02 Coupe. It has been cooler the past few days in Florida (this morning was around 37F, and the windows went down 4 times!). We also had very heavy rains Thursday, and signficant flooding, which I drove in. Friday was the first day this started for me. My instinct tells me that the window control wires are pinching the shifting mechanism, or that this wire is shorting out due to age. But I could be wrong. Have you pulled the center console area apart by chance to see if this was a symptom?
