08C2S. Anyone know where I can get an exploded diagram of the 997 headlamp that shows its internal components?
Since there are no internally serviceable components (other than bulbs of course) I do not believe Porsche provides those to any service personnel. And, I doubt they would release any design documents.
What are you trying to accomplish?
Perhaps disassemble one from a salvage yard?
Loren,
inside the housing and just in front of the low beam bulb, there is a cicular lense (concave) about 3" in diameter. Trying to see if this lense is available as a seperate item. I did try the dealer and as you said, Porsche does not provide internal parts to them beyond the bulb.
Thanks Loren. I did check out salvage companies and e-Bay and either way, people want at minimum, $100.00 even for a damaged unit (chips around the edge, etc.).
Check out the BMW elipsoid headlamps, may be the same internal lens? We have a lot in the UK but don't know about in the USA.
