The sheet metal speed nuts have been superceded by plastic washers that appear to just push onto the studs on the emblem. It's not as easy as it sounds, however, as while you could hold the old style nuts in your 8 mm socket, that's not feasible with the new part. It's also unclear which side of the washer goes where.
Any experience and tips here?
TIA
