Ok, I thought Pin 69 was part of what got removed from the engine harness. the factory wiring inside the car has not been altered as far as the A/C system is concerned. Only the engine bay harness has been removed from the car. The enigne RPM signal now comes from the GM computer that ties into the DME Pin 78. I'm thinking the DME is looking for either a running engine or some sort of signal that it isn't getting or isn't there for the system to be properly activated.
So Pin 69 @ the DME and Pin D6 @ the AC unit are factory.
Do you have the full wiring diagram of your car? Sorry can't tell from your reply, are those two pins connected currently? If not, you need to connect them. Basically you need to restore all connections between the AC control and the DME as per the wiring diagram that was removed together with the engine harness.
Yes I have a wiring diagram of the car. The 2 pins are connected correctly, they were never touched throughout the engine swap process. Only the engine harness was removed (2 cannon plugs in engine bay).
Does the DME use things like throttle position etc... as a funtion of controling the AC in this case?
Got it now. So pin 85@relay is still connected to pin 62@DME, right?
I think it's quite possible the DME uses the throttle position sensor (pin 44@DME) as an input because if I remember correctly, the AC compressor will be cut at WOT. Also, the other potential input could be the coolant temp (pin 74 @ DME). I wonder if the AC compressor will be cut if engine is too hot or too cold.
Yes 85 & 62 are untouched, and Pin 85 is showing 5~6v with the relay removed, and with the relay installed it shows 12+v.
Do you know what the voltage range is on the throttle position sensor...maybe I can tie it into the GM sensor which is .5~.6v @ idle and 4.5v+ @ WOT.
I do have a stock Porsche temp sensor, it has 4 pins on the sensor but I'm not sure how it should be wired.
At this point I'm going to try to find an engine harness so I can tie in as much as I can so both computers "think" they are operating normally, haha...
I do not know the throttle position sensor output voltage since mine is e-gas. However, from the wiring diagram, it looks like the sensor uses a 5v reference so I would expect the signal to be between 0 and 5v, just don't know if the voltage goes up or down when you press on the gas pedal. I think you can just give 0v or 4.5v to pin 44@DME and see if that makes a diff to your AC relay.
Temp sensor, pin 1@ sensor to pin 74@DME and pin 4 @sensor to pin 34@DME (ground). Pin 2&3 can be ignored. You should see this from your wiring diagram.
Edited by Ahsai
Cool, I'll check that stuff out tomorrow. I'm not real good at following the wiring diagram when it goes from one harness to another. when the wires end in those boxes with the letter and numbers that you chase to another diagram.
Can you tell me which pins on the engine harness cannon plugs you're referring to above?
Where are you from man? I'd invite you over and pay for all the beer if you were in Lauderdale, haha, really appreciate the guidance, helping out a ton!
Anytime! It's fun to help if I can :) I'm in SoCal.
Coolant sensor
Pin1->x59/2 pin 12 -> pin 74@DME (NTC water)
Pin4->x59/2 pin 21 -> pin 34@DME (Ground sensors)
Throttle position sensor
Pin 1->x59/2 pin 21 -> pin 34@DME (Ground sensors)
Pin 3->x59/2 pin 23 -> pin 44@DME (TV-signal)
Pin 2->x59/2 pin 22 -> pin 53@DME (5v supply)
X59/2 and x59/1 are the two 25-pin round connectors of the engine harness in the engine bay. The ones you called canons. X59/2 is the same one the crankshaft sensor is on.
Haha, I know but that's what it says in the diagram. My guess is "TV" probably refers to throttle valve.
Btw, based on the throttle valve pin out above, you can rig something up with a 5v supply (e.g., USB charger) to test your old throttle body and check the signal voltage range when you move the throttle valve so you know for sure.
Any idea why I'm getting battery voltage with Key-On at Pin 85 on the Relay, if the DME provides a ground to this Pin, shouldn't it be open w/ no voltage?
With the relay removed even, the pin (85) going to the DME is showing 5~6v, why would there be positive voltage if this is the wire that is supplied a ground via the DME when commanded "ON"? Shouldn't it be an open circuit with the A/C off, neither grounded or any positive voltage supplied?
No, because its driven by a transistor. Without load, the voltage reading usually is not conclusive anyway due to the nonlinear nature of solid state circuits. What matters is with a good relay connected whether it can supply a solid ground to that pin.
Well I did get another AC relay...used albiet, but just for testing I guess. Hopefully will have the system serviced back up tomorrow and be able to check the new relay and see if it really was that simple. We'll see...
If it doesn't work I'm going to take it to the dealer or to a Porsche specialist in the area to see if they can hook up a scan tool with the ability to test the circuit to see if the DME or AC control unit is faulty I guess.
Edited by pdogfly
  • 3 years later...
  • 6 years later...
I have this same issue and was hoping to find the solution here. I’ve come back to this thread a bunch and am hoping someone can explain the solution or even next steps.
My situation is same as OP, LS1 swapped 996.1. I’m not getting the correct signal form pin 69, the snowflake button does give a 12v PWM signal but it’s very low current, can’t even trigger a relay. I believe this is the correct signal, but I’m curious if it’s actually a ground signal which is common in German cars.
Any insight would be appreciated!
