Workshop Campaign WE11. Replacing vacuum lines for sound symposer. The lines on the change over valve can slip off due to engine vibrations. A faulty cooling system message can be generated due to the open vacuum line. They replace the vacuum line and the clean air line on the change over valve.
Thanx RJN,
Yes they were doing it when the cars got to the dealer. I suspect the factory has it under control now and the cars are coming good to go. We will find out in ONE MONTH!!! (double flip here)
