Have you tried VW (T10152) for the tool? It is also used on the Cayenne and VW Toureg.
You WILL need the tool.
Removing
1. Carefully lift up rubber sleeve on the ignition switch using a plastic spatula, for example, and remove it.
2. Turn union nut using a narrow plastic spatula, for example, or using the special wrench T10152 tool and unscrew the ring from the ignition starter switch.
3. Press ignition switch inwards and remove towards the bottom.
4. Release electric connector -a- and pull it off the ignition starter switch
Installing
1. Connect plug on ignition switch until it clicks into place.
2. Position ignition switch in the switch panel from below. Position union nut, re-adjust switch and tighten union nut using wrench T10152. Tightening torque: 1.6 Nm
3. Place cover in position and slide it over the ignition switch, paying attention to the fitted shape.
  • Like 1
  • 7 months later...
