I have pulled the hub to replace the bearings. When the hub separated, the front half of the bearing is still attached to the hub. How can i remove this from the hub shaft?
What tooling did you use to pull the hub?
Heat may be your friend here, heating the remaining section will expand it and it should come off with some "encouragement".
Thanks for your input. I used the Sir Tools puller. I was able to use a Dremel with a cutting attachment without damaging the hub.
