Does anyone know how to change the emergency brake handle? Could use diagrams etc.
2004
c2
996
6 spd
stan
  • 2 months later...
Loren,
Do you know of a why to simply remove the handle grip and not the entire assembly? :help:
No I don't, I've never tried. Do you have just a hand grip? What are you trying to do?
I'd like to do the same.
I have a wood handbrake handle/button that I'd like to switch with my wood/aluminum-look hand brake handle and button. That would allow me to keep the matching leather and stitching.
I thought I might just try unscrewing the button and pulling off the handle, but thought it best to check around first.
yea, that is pretty much the same requirement as mentioned by hspiva. The grip is tired and the button is a little worn so I was orginally told that the leather is simply wrapped around the grip and would slide off. But if I need to replace the whole assembly, I guess I better.
