Hello Forums,
Just got the Brake Pad Workshop light on. Does anyone know how much distance is left before I -really- need to change my pads and rotors? I am stopping by Oregon in 2 weeks and want to pick up parts there (200$ cheaper than in Vancouver, Canada).
2 Other questions:
1. How do I measure the brakes myself?
2. How do I tell if I should replace the rotors?
Thanks.
Chris.
Take a look in the diy section...I did write ups on everything....
Bottom line... you have several thousand miles of easy Street driving before you start rubbing on the backing pad.... got should be fine....
For rotors unfortunately the wear limit is so small youtypically end up replacing the rotors every time. .. or every other I'd you have a soft pad
