The LN instructions for the IMS bearing install say to "use a Snap-On dead blow (red, plasticized hammer)." But there are many such hammers in the Snap-On catalog. Is there a suggested weight that is best?
The Harbor Freight store sells orange plastic dead blow hammers in 1 lb,, 2 lb., 2.5 lb., 3 lb., 4 lb. sizes. Since I have to go buy one, it may as well be of the recommended weight value.
We use a 3 lb. dead blow, works fine.
Thanks. HF 3 lb. is $10, and has a striking face diameter of 2-2/5" = 2.4" or about 61 mm. The IMS bearing OD is 47 mm so it should more than cover the insertion tool's face.
It's amazing how many loose ends there are in preparing for an IMS bearing service. Since I have a 2000 I'll still have to pull-and-inspect prior to ordering the darned bearing anyway. The green wicking Loctite is #290, right?
Edited by Dennis Nicholls
Loctite 290 is the green wicking product.
I've always been leery of green Loctite. It is supposed to be almost impossible to get two parts separated when jointed with green Loctite. If you ever had to go back into the IMS.....could it be disassembled?
Yes, just don't go crazy with the green Loctite. Its purpose is to wick into the nut threads and prevent oil from seeping down the threads, not to lock the fasteners together.
So basically just a drop or two after torqueing the nut, placed on the threads just outside the nut.
Hey I got my hammer. HF sale for $9 with a 25% off coupon, net price $6.75. The LN tool kit is on order, paid $240 shipped.
