Installing a HID kit on my 99 C2 996 found this. Anyone has an idea where I can get the connector that is in the headlight assembly and connects to the headlight base?
I just been saved from something catastrophic.
post-15979-0-09129600-1396975861_thumb.j
post-15979-0-57049800-1396975884_thumb.j
post-15979-0-14751800-1396975916_thumb.j
On Pic 1, Red circle, is this the high beam?, Yellow circle, is this the low beam?, White circle, is this the Fog light?
On Pic 2. Red and Yellow circle, what are these for?
On Pic 3. The Red circles, that is what you have to unscrew in order to take out the headlight base?, is the screw on the far left the one to adjust the beam? These screws have a thumb screw in the bottom. I want to take out the headlight base because there is something where that the headlight assembly get stucked with. Thinking that if I mount the headlight assembly on the base while being out of the fender I could see what may be causing the headlight assembly to get stucked.
post-15979-0-58644300-1396990517_thumb.j
post-15979-0-29268700-1396990561_thumb.j
post-15979-0-02717900-1396990848_thumb.j
