Can't get the rear driver side selt belt to retract back, so it's just kind of hanging loose on the seat. Any trick or quick fix to get it to roll back up again? Tried twisting and yanking on it to get it to pull back, but no luck.
Did you try to pull it out slowly all the way first and then release? You can try to pull out a little bit and feed it back in, back an forth, trynig to unlock that ratcheting mechanism. Be patient and you may be able to unstick it.
Edited by Ahsai
