If I have oil in the spark plug tubes, can I simply replace the tubes, or is more work necessary?
Depends upon the year of the car; which one are we talking about here?
Thanks. Do you know if the camshaft covers need to come off, or can you pull the tubes out with a boat drain plug?
Cam covers need to come off, which requires special tooling.
Sorry, forgot that. 2005 997.1 C2 3.6L MT
Mmm... I think 2005 will have the metal tubes (different design).
How many spark plug tubes have oil? How much oil?
This sounds very odd for these later model engines.
Mmm... I think 2005 will have the meal tubes (different design).
Two tubes, enough oil to drip out at a good rate.
Edited by Phil_D
Thanks for the help, appreciated.
Loren, the part I was thinking of is 996-104-203-00, which sits under the cam cover and seals to the plug tube on the 2005 997.1 engines.
JFP, I think I got thrown with the word "tubes" since they are part of the engine in the post 2001 designs.
Have you seen those gaskets leak like this before? I have not -- but then these engines are starting to age...
I've not seen any of them leak, but we have changed a few while doing other maintenance items that required pull the cam covers. They do take a "crushed" shape when compressed and could leak if the cover was loosened or removed and they were not replaced for some reason.
I am not the first owner of this vehicle, but from the service history I have, the cam covers have never been off. I will post an update of what is found once I get it taken care of.
A quick update. Had all six tube seals and plug seals replaced. $50 in parts, a whole lot more in labor! Had the AOS replaced at the same time, as the motor was out of the vehicle and it seemed like a good time to change it.
Edited by Phil_D
