After replacing the ECM for my 05 Porsche Cayenne Turbo, I noticed it starts for a second then quits. Does the ECM have to be reprogrammed by PIWIS or can I use My Durametric cable?
The Durametric cannot reprogram the DME, but replacing a DME usually requires some setup with a PIWIS unit so that the immobilizer, etc. are all in sync with the new unit. You cannot just pop in a new DME and go.
