$200+ for one pre-cat sensor on my 2006 turbo. Anybody have a cross reference part number from one of the usuals? I am sure that NAPA only wanted $80 or so last time I asked but I want to make sure I get the same connector as the OEM supplied unit
Steve
I suspect that Andrea quoted for the pair rather than the one I need. My local AdvanceAuto list a Denso as direct fit at $106. Would it be a problem to just replace one with a Denso?
Steve
Steve
If its technical specs match OEM, no it would not cause a problem.
Does the Bosch 17174 have the same plug on the end or will I need to change it?
Steve
Thanks all. Ordered online for $75 and free shipping Vs $205 from Sunset. Apparently Porsche does not support "aftermarket" items. Lets hope it fixes my perpetual random bank2 misfire problems....
Steve
Just curious, were you getting any fault codes related to the O2 sensors? OBDII has specific fault codes for O2 sensor related faults.
Yes, curious. All of Bank 2 or just random cylinders? Coil wiring? Injector wiring? Don't want to go negative but I have seen low cylinder compression throw a cylinder misfire (probably one of the least likely situations, especially considering it's a Turbo).
