I've had my 2000 base 986 for two months now. I've put on a little over 1K miles since I've owned it. Present mileage is 52K. So far I've performed the following checks.
- Changed and inspected the oil filter twice at 600 mile intervals from the last oil change. Filters look good with no metal debris.
- Durametric reports over-rev R1 4023 and R2 0 (zero). Sounds good to me.
- Engine serial number has a "Y" in it, indicating "most likely" a dual row IMSB.
- Cleaned and scrubbed the "weep hole" where the engine mates with the tranny. I wanted to get the old brown cosmoline off the area so I could more easily detect any oil leaks if present. So far no signs of oil there at all.
- Last week's Durametric readings of camshaft position deviation are as follows:
-- Cam pos dev bank 1 -4.42* at idle and 2K rpm
-- Cam pos dev bank 2 -4.25* at idle and 2K rpm
I drove the car 20+ miles before the test so the engine was fully warmed up. In both cases I watched the graph and numeric display for a minute or so and there were no changes in the numbers reported. These aren't "good" numbers but IIUC they aren't "terrible" numbers either, as the spec is purportedly +/- 6*. I'll keep a log of the deviations with age and mileage to see if there are any rapid changes.
Anything else I should check now? I'm putting off the "pull the tranny" exercise until summer since my age makes working in cold weather difficult. I've got a new clutch and RMS, and have a spin-on filter adapter on order.
Edited by Dennis Nicholls
Add a magnetic drain plug if you do not already have one, it helps alert you to ferrous debris if it starts to occur. I would also definitely add an IMS upgrade while doing the clutch, and also change the AOS while the tranny is out and it is in the open.
Actually there's no sign of RMS problems and my clutch is working just fine. The whole reason for the "pull the tranny" exercise is to determine "for sure" whether I have a single row or dual row IMS bearing.
Just a "heads up". My dual row IMS failed at 58,000 miles. If I had the transmission off for whatever reason I'd certainly upgrade the IMS. It's just not worth the gamble. Luckily, I replaced mine just before catastrophic failure, but I still don't know how much damage was done from the tiny bits of metal that flaked off the bearings before I caught it.
