Hi8... It would be easier if you had the part description included, if item 18 is the single post terminal, then that would be the battery + lead to the terminal post included on the attached pix, then from the terminal to the starter, I think???? Anyway that terminal post housing on my 2003 C4S is on the right side frame at about the firewall. It's hiding high on the frame...
post-85466-0-60334300-1396132489_thumb.j
Edited by creekman
