My '99 996 Tip Cab has been having central locking issues. Initially it would beep when locking/unlocking, but I tracked that down to the microswitch in the passenger door and fixed that. Now, just a couple of weeks later, the key fob stopped working suddenly. Normally I'd expect reduced range with a battery issue or unreliable opening if it was a contact problem, but I saw none of those symptoms. To be sure I switched to a new battery and checked that the key fob board all looks good. Still it is completely dead.
I checked the car with my Durametric and got the following codes. I assume that may have come from when my microswitch was going. If I try to clear the codes, they come back with the same counts on the next restart.
I don't have another key fob to try it, so apart from getting new key fobs and paying the dealer $$$, I'm stuck for a next step.
Could there be some other problem that would cause the alarm to chirp once and not open or close the car from the key fob???
Alarm I32
Module Identification
Part Number 996.618.260.07
Supplier Part Number 00
Current Fault Codes
47
Control locking synchronization
Status: not present
Occurance Counter: 6
This fault is displayed for informational purposes, it is not an indication of a problem and no repair is needed.
61
Central locking limit position Unlock not reached
Status: not present
Occurance Counter: 62
21
W lead (DME immobilizer)
Status: not present
Occurance Counter: 1
60
Central locking limit position Lock not reached
Status: not present
Occurance Counter: 2
33
Interior sensor faulty
Status: not present
Occurance Counter: 20
Fault code 21
W lead (DME - immobilizer), open circuit
Possible cause of fault
- Short circuit to ground/open circuit in the communication lead between the alarm system control module and the DME control module
Fault code 33
Passenger compartment: monitoring sensor faulty
- Passenger compartment monitoring faulty
Fault code 47
Central locking synchronization
- Short circuit to ground/open circuit between alarm system control module and door locks
- Door lock faulty
Fault code 60
Central locking limit position 'Locked' not reached
- Central locking switch faulty
- Short circuit to ground/open circuit in wiring between the alarm system control module, central locking switch or door locks
- Driver's/passenger's door lock faulty
- Control module faulty
Fault code 61
Central locking limit position· Unlocked not reached
- Incorrect country coding
- Door lock (driver's/passenger's) faulty
The most common fault 60 and fault 61 faults we have seen are mechanical latch/lock problems in the door latch mechanism.
Fix that then clear the codes and see if any come back (perhaps the Passenger compartment: monitoring sensor fault).
On a related topic, I replaced the central locking module under the driver's seat in my 2000 Cab4. I did not have the key codes to enter into locking system so I can only open the doors manually. Is there anyway to discover the key codes? Dealer did not know of a way.
Maryland
If you
Maryland
If you do not have the 40 digit codes that came with your key(s) then you will never be able to program them in - you would need to buy new keys.
