The CDR23 in my 03 996 cab is not making sound. All buttons and displays are working but no sound from speakers. Does this indicate a defective amp? I have non Bose with MOST (at least I think I do). Any and all suggestions would be greatly appreciated.
Thank you in advance
I'm sorry if I broached the rules of the forum or offended anyone.
You have not - you are asking about a fairly common problem and there are many threads on it. It is always best to search first as others have likely had the same issue.
  • 2 months later...
Turned out the problem was the amp and not the CDR23. I bought and installed a refurbished amp and installed it and my problem was solved. Thank you all for your suggestions.
