Hi all,
I'm looking for a fix for a 2004 Cayenne S which has a fault in the PSM/ABS 8 system. Fault code is 1673. Distance sensor in brake booster. Electrical fault.
I have found links to a TSB but cannot find out the details of this TSB.
Reference number of this TSB is ATI-0903.
Has anyone come across this before?
Thanks in advance.
Adam
I just checked on PIWIS and there is no TSB with that number.
There are no TSBs for PSM related problems for that model year that I find at all.
Fault code 1673
Possible cause of fault
- Actual value of 'distance sensor in brake booster' is evaluated as implausible (implausible signal)
- Short circuit to ground (electrical fault in electric circuit)
- Short circuit to B+ (electrical fault in electric circuit)
- Open circuit in circuit to control module (electrical fault in electric circuit)
Have you followed the troubleshooting diagnostics in the service manual?
