I was considering getting for my 02 Targa some HRE 543's (18") and wanted to know how wide can I go for Front / Back, in Wheel Width / Tire Size / & Proper Offsets.
PS> I am going to most likely upgrade to a PSS-9 system in the future as well.
TIA
lap
Here are the Porsche approved tires:
Tire Size
Front: 225/40 ZR 18
Rear: 285/30 ZR 18
Tires:
- Bridgestone Potenza S-02A N3 Directional
- Continental Sport Contact 2 N2 Side-directional
- Michelin Pilot Sport N1 Directional
- Pirelli P-ZERO ROSSO N4 Side-directional
Approved 18 wheels (w/offsets) are:
- Front: 8J X 18 offset - 50.0/52.0
- Rear: 10J X 18 offset - 65.0
5 mm spacers are approved on all four wheels.
17 mm spacers on the rear wheels and 5 mm spacers on the front are also approved with use of proper (longer) wheel bolts.
"Unofficially"
With the 8" front wheel you can go 235/40 ZR 18 tire without any rubbing and it will reduce understeer a little. A couple of brands of 295/30 ZR 18 rear tires are reported to not rub (or require fender rolling) but I can't recommend any especially if you are lowering the car.
Perhaps you can tell if this is a street car or track car and others can recommend tire/wheel combinations for both.
Thanks Loren!
Some additional points:
1. 2002 Targa = Primarily Street Car (for SPIRITED DRIVING) & some track
2. OFFSETS: you mentioned: ... Approved 18 wheels (w/offsets) are: Front: 8J X 18 offset - "50.0/52.0" is that a range? Also, if 5mm spacers are "allowed" in the front, cannot I get that "built into" the wheel (Fr and Rr) from HRE? I don't think I want to risk the 235's up front unless I know for certain that I will not have "rubbing", BUT I definitely want to reduce understeer.
Right now my 1989 speedster w/ Koni Yellows feels much MORE connected, I know they are completely different creatures but I would like to get that same feeling in the newer car.
TIA!
All the Porsche OEM wheels are either 50 mm or 52 mm offset. I don't see any reason why you can't get the 5 mm offset built into the wheels (as long as it is correct).
I don't think the 235s will rub even with the 5 mm spacers. The fronts rub first on the inside -- and only 245s rub a little at lock to lock.
Ok Loren,
Just so I don't screw this up,
1. what are the exact #'s to give HRE (w/ the most agressive offset built in, i.e. no extra spacers required)
2. 235's will work w/out rubbing? b/c you indicated "the fronts rub on the inside"??
THANKS AGAIN!
LAP
One of the good things about buying custom wheels, is that you select the offset. If someone has a OE Carrera style wheels (which have 52 & 65mm offsets F/R) and they throw a 7mm spacer on the front and a 17mm on the rear, then they have an affective offset of 45 & 48.
Offset (or ET, which means 'pushed in') is decreased as you 'space' the wheel out.
Personally, I'd say there's nothing wrong w/OE tire sizes (shoot, the Turbo runs 225s in the front). If all you're after is good looking relationship of fender-to-rim (and not concerned about any of the possible negatives that go with it) then your car can handle the offset I described above (with 8J & 10J rims and OE rubber) even if the car is 'somewhat' lowered.
Here's a pic of same.....good luck.
  • 5 months later...
1999 C4 Cab
Would these RIMs fit on my car?
Front ET50 18x8 w/ Tires 225-40
Rear ET45 18x11 w/ no tires
According to Loren's post above, these rears seem too big?
How about these?
18" Porsche Turbo Staggered Wheels
18 x 10" Rear Wheels, offset ET40
18 x 8" Front Wheels, offset ET52
Porsche part #'s 893.362.140.00 and 893.362.136.00
What does the J stand for in Loren's post?
Where can I find out the best offset for my 99 C4 Cab? These are 5, 45, 40, and 52 but I'm new to this and don't know where I can reference the best offset for my car.
Thanks again for all the help!
Edited by gry
