I have been intermittently getting cel and code P0159 and P0160. I have plugged in my software and the post cat O2 sensor voltage was reading quite stable. I opted to clean the electrical connections only at the weekend for the post cat sensor. Today my cel returned, to find a new code P1276. Could this be part of the same problem. My post cat sensor is now reading 0v constantly. Do I need to be changing sensors if so both or just one?
Seems all the codes point to your bank2 postcat sensor. Maybe you could check the wiring first to make sure there are no shorts. Also wiggle the wire to see if the voltage changes. If it's not the wiring, most likely it's the sensor itself, especially if it's beyond 60k miles. For replacement, you could check Bosch here http://www.boschautoparts.com/VehiclePartFinder/Pages/VehiclePartFinder.aspx
Edited by Ahsai
You should not be using electrical contact cleaner on the connectors for O2 sensors, that alone can permanently damage the sensor.
