05 Porsche cayenne turbo. 145 - right rear damping adjustment valve. strut or level sensor? I also checked the wire harness on the level sensor and no corrosion was found. p0299 turbo under boost. p0344 no signal with bank 1 cam sensor. I had replaced the cam sensor a year ago and checked the reluctor wheel, wheel was OK.
forgot to mention that all work was checked with Durametric equipment and the cam sensor had zero signal.
